Go Back   Automotive Forums Car Chat > Buick > LaCrosse/Allure
Old 03-08-2014, 01:05 PM
eccs19 eccs19 is offline
Key Fob Issue
06 Allure - Fob was working, then just stopped. I've fixed the fob in the past due to cold solder and added a sheet that fixes the buttons that stopped working, and after I did all that, it worked great. Replaced the battery in it, but it's still not working. Solder joints are still fine. I'm wondering if it might be something on the car's side. No idea how to check if one or the other is working properly or not, so looking for suggestions.
Thanks in advance.
Old 03-08-2014, 01:38 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: Key Fob Issue
Only have one fob? You can take your key fob to the Buick dealer parts department. They should have a tester and check it at no charge. Then you'll know where to start.
Old 03-08-2014, 08:29 PM
Re: Key Fob Issue
Yes, only one fob. I'll check with the local dealer and see what they have to say. Thanks for the tip.
