Old 03-07-2014, 06:07 PM
rabbit507 rabbit507 is offline
Sounds like a broke shock
I've got a noise in the frontend of my 04 blazer that I cant fix I've replaced both shocks, all tie rod ends, upper and lower ball joints, gearbox, and nothing works. I've looked at the rubber bushings and can't find any missing but when I hit a bump or pothole it sounds like I have a broke shock what can it be someone help
Old 03-08-2014, 08:24 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Sounds like a broke shock
Have you checked the sway bar links and bushings?
MT
Old 03-08-2014, 12:19 PM
I've pushed, pulled and looked at everything I can think of. I've spent over $1000 bucks and haven't got any results except now I've got a new frontend lol. I love my blazer but it's literally driving me crazy I'll check your suggestions thanks for your response. Oh and my tires are wearing evenly so that's a plus. I want to thank DelCoch it was the hood hinge washer causing all that racket.
Old 03-08-2014, 12:23 PM
one more problem I'm having is the heat and air don't blow out on the floor only defrost and front of the dash have you ever experienced this problem?
Old 03-08-2014, 06:53 PM
DelCoch's Avatar
DelCoch DelCoch is offline
I've got a noise in the frontend of my 04 blazer that I cant fix:
Sounds like a loose hood hinge. Sometimes the obvious escapes the brightest mechanics. See this post:
http://www.automotiveforums.com/t302...ix__read_.html
Enjoy,
The Following User Says Thank You to DelCoch For This Useful Post:
rabbit507 (03-09-2014)
Old 03-09-2014, 09:54 AM
Blue Bowtie's Avatar
Registered Offender
Look at the large (~3" dia) washers on the bottom side of the body mount bushings at the front and intermediate positions. They may be damaged or missing. Mine were, and it hammered/thumped over large bumps.
Old 03-09-2014, 11:50 AM
I don't know what to say except THANKS!!!! that is the problem. I spent over a $1000 bucks but now I do have a new frontend lol can I replace them by myself or do I need help?
Old 03-09-2014, 11:43 PM
DelCoch's Avatar
. . . can I replace them by myself or do I need help?
Just do one bolt at a time & it's a DIY type thing.
Old 03-10-2014, 09:49 PM
Thanks
