Old 03-07-2014, 01:27 PM
illmami illmami is offline
please some one help with my blower problem
Ok heres my problem first i hav a 97 lesabre limited i turned my car off took key out my heat stayed on i had to disconnect from blower motor then i bought a used resistor replaced it now the blower doesnt turn on at all while i was disconnecting the relays to get to the resistor my husband bumped the relay ground on the frame and it sparked i took over and wrapped it up with electrical tape anyway now i dont know if something shorted or the used resistor is bad ive checked the relays by switching it with another same volts and nothing.can anyone give me an idea please
Old 03-07-2014, 08:40 PM
Tech II Tech II is offline
Re: please some one help with my blower problem
If this is a Limited, than does it have Auto Temp? If yes, it doesn't have a resistor block, it has a blower module....
Since something sparked, check all your fuses......
Old 03-07-2014, 08:49 PM
Well the part i bought was classified as resistor it does have automatic climate cont. Guess it could be a module either way it looks like a mini amp anyhow ive checked the fuses under my steering colum under the hood im totally lost i dont know where to look
Old 03-08-2014, 11:26 AM
Yeah, if it has an aluminum heat sink, it's a blower module....how do you know the used one is any good?.....put the old one back in, CAREFULLY(actually, just disconnect the harness and attach to the other one), and see if it runs the blower....if it does, that "new" one may not be good.....
If it doesn't run, by attaching the old one, must have blown a fuse....there is another fuse panel, I believe, under the instrument panel, towards the right, on the passenger side...remove the hush panel...bunch of relays and fuses there too....
Bumping a ground, should not cause a spark.....bumping a live wire, like that cable going to the bracket that has all the relays under the hood, will....
Old 03-08-2014, 11:51 AM
Found a schematic for a '97 Grand Prix with a blower module....should be the same.....
5 wires.......harness disconnected.....with key "on"(engine not running), A/C in DEF, blower on HI..... terminals "C"(grey/blk), "D"(brown), "B"(orange) should all be hot with a test light......"E"(black) is your ground(attach your test light to this while checking the other three lines...it confirms your ground is ok)....purple wire goes to blower.....
Old 03-08-2014, 03:07 PM
imidazol97 imidazol97 is offline
AF -Advisor
I'm not sure what was bumped, but I agree with putting the previous one back in to see if it works. You may have only connected a ground with power through it causing a spark.
I'd suggest taking off the negative lead on the battery while working.
You have a 30 amp maxifuse in underhood fuse block in the relay center: A3
You have a 15 amp fuse in IP fuse block 5A
You have a 10 amp fuse in IP fuse block 9C, those are the column and row numbers, don't recall which is which.
AND you have a feedback fuse from the fan to the blower control module, the part you were replacing, which is under the passenger side instrument panel --on the wall of the A-pillar. There's a fuse chart on the top of the thin plastic panel under the dash that you take off for easier access to it.
10amp Fuse #11
Old 03-08-2014, 10:06 PM
Thanks to all for ur help i borrowed a fuse tester from a mech. Im going to check all of them tomorrow i found the hidden fuses behind the glove box and there is that possiblity that the newer module is bad. But thanks im trying all of the above
Old 03-10-2014, 06:15 AM
Ok so i found the fuses under glove box does anyone know if theres a specific one for the blower?
Old 03-10-2014, 08:31 AM
Did you do the voltage checks I suggested in post #5?
Old 03-10-2014, 08:37 AM
I used the tester thing to check every fuse and under the hood im lost have no idea what else to try
