Old 06-24-2003, 06:45 PM
integ92 integ92 is offline
moving my battery to the trunk
Yes i was woundering if anyone knows how to move the battery from engine compartment to the trunk what will i need and how hard is it. :
Old 06-26-2003, 08:00 PM
darkaccord darkaccord is offline
Send a message via AIM to darkaccord
Without a doubt it would be very difficult and probably not worth your time. If you do, remember the negitive terminal must be grounded to the chasis.
Old 06-28-2003, 08:42 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
why do we want to do this ?
Old 09-02-2003, 09:22 PM
Heppen Heppen is offline
I could guess of atleast two reasons to move the battery, 1.) to make more room in the engine compartement for something more usefull and 2.) to increase theft protection.
Also you can _lock_ the trunk.
What I would be most conserned with is not to risk getting battery acid in places I don't want, but an acidproof battery-box of some sort securely bolted in place in the trunk would do the job, and for power distribution you can allways buy power-cable per ft. in stores dealing with car audio equipment.
Good luck!
Old 09-24-2003, 05:33 PM
sniperscrubb sniperscrubb is offline
Your battery has to vent, buy a BMW battery with a venting system. You need heavy duty wires to extend the wires- 0/1 gauge. You need something to hold the battery int he trunk so it wont move, you sure you want to do it? Lots of work.
Old 09-29-2003, 09:45 PM
killah_xft killah_xft is offline
Send a message via ICQ to killah_xft Send a message via AIM to killah_xft
you don't have to run 0/1 guage wire, are you nuts? you can get by easily enough with 2 guage, just be sure you run a good solid wire from your alternator to the battery in the trunk, and back out to the inginiton system, and A/C. distribution blocks come in handy here. I would suggest a nice 4 port gold block... and a good sealed battery, like the new Optima yellow top. they have great power, and are recommended for high power sound systems. they are'nt cheap ($140), but they are the best out there...
Black 1999 Honda Accord LX, Bombz Cold Air Intake, DC Sports Ceramic Exhaust header, "Rally racing" Foglights, 400 watt coustic 401SE AMP, 450 watt Bazooka TVB 141 Tri-vent triangle sub. 220 watt Pioneer 6.5" 3-way (in doors).
To come: Dynamat, Borla exhaust system, and 17" Koenig Absolute (black w/ chome lip), Coilovers, & camber kit (1-1.5 drop), Extensive Engine mods.
check me out on: http://www.cardomain.com/memberpage/515191
Relocating the battery to the trunk Alejo_nin '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 06-21-2004 08:08 PM
Battery in the Trunk eillob Mustang Talk 6 06-02-2004 02:35 PM
Finished my battery in the trunk install... FourthGenHatch '88 - '91 Civic | CRX | Wagon | Shuttlee 27 03-11-2003 10:00 PM
Movin the battery to the trunk bc4g '88 - '91 Civic | CRX | Wagon | Shuttlee 17 02-06-2003 06:32 PM
battery in the trunk teg2nd Engineering/ Technical 10 10-02-2002 12:58 AM
