Old 03-01-2014, 02:38 PM
lanesteele240 lanesteele240 is offline
Ferrari f430 challenge ika musume 2nd edition
This is the 2nd livery for this car. The first one i built was so cool i had to get this one.
Im doing alot more to this one. Crazy modler pe set. Open doors wired interior. I hope i dont re-re-re-burn out and quit before i get this one fin.
Here we go
Here is the first car and decals for the second car.
Here is the front skid plate covered in carbon.
Rear skid. Touch up is needed. I got a little fustrated and had to walk away from this stage
Door busted open.
I made the door jams with multi-put 2 part epoxy
All i did was put some petroleum jelly on the parts i did not want the pox to stick to. Dry fit the interior tub and chasis to the body and push the pox into the door jam and shaped it to what i wanted. When cured, the body poped right off the pox area and i had door jams
More shaping with putty is needed to finish.
Old 03-01-2014, 02:42 PM
Re: Ferrari f430 challenge ika musume 2nd edition
First livery
Decal sheet
Race day photo.
Old 03-01-2014, 02:44 PM
Doors next
I taped the door back in place
Then i added flat stock to the back of the door inner
Then i snipped off the flat stock till it fit correct and glued it in place
Here i did the same with the pox to the door.
Remember you can smooth multi-put with a damp finger. Also any pox that got on the door in a undesired place can be easily washed off with a water damp towel. It is way hard tomsand that stuff off after it cures. A wet handle of a brush can also be used to smooth out the epox
Old 03-01-2014, 06:54 PM
Roll cage
I added the white roll bars
Old 03-01-2014, 11:49 PM
countach79's Avatar
countach79 countach79 is offline
Good work mate!
I really appreciate your wip so far and the detail you are giving about your work
I have always wondered how these blokes do these door jams and making the door panels fit properly, I've never really used milliputt, so cheers mate!!
Old 03-06-2014, 12:17 AM
I added a shifter that i robbed from another kit
I added some string to make a set plug wires and glued it down with future
Here is the engine bay. With a diffrent tranny that better matched the one on the car
Another shot
I may cut the rear hatch out so all the detail will show.
There is a decal that goes on the back glass that will cover mutch of the bay
I spent 1 hour putting carbon on the the vent thing but now it wont be used
Old 03-07-2014, 07:20 AM
Here is the edward printed seatbelts
They were a hoot to put together
If you ever get a set of these, put the belt part on the buckle part and then cut the buckle off the spure
I cut the rear hatch off and had one of those, what have i got myself into moments.
Old 03-07-2014, 11:23 PM
Dashboard and comtrols
It is starting to take shape
This is how i figured best to add the belts to the metal parts.
Old 03-09-2014, 01:49 AM
michel1973's Avatar
michel1973 michel1973 is offline
Great work so far
my English is not perfect but hopefully be readable
Old 03-12-2014, 08:38 AM
Sorry for the break but i had to spend some time with the wife
I fixed The hatch with some flat stock
I cut out the hood duct
I added the vent parts and It looked good till i sprayed some primer on it. I knew the ca filler would need some more attention though
Thanks for looking
Untill later
Old 03-13-2014, 06:09 AM
countach79's Avatar
I'm lovin this build!
Keep up the good work
Old 03-20-2014, 10:10 AM
Stoppers.
I just glued the outside to the rotor. I have been down the full pe rotor road. It leads to wheels popping off out of thin air and u dont even ser it if you put the wheels on
Old 03-20-2014, 10:14 AM
I got around to finishing the intake tubes
I had to repaint the interior. It turns out it is sliver instead of black. While i was at it i scratched a console and made the shifter more like it should be.
To match my first build i have go get some racing white. I some how picked up bright white. That is going to be a small hold up since my lhs is a long trip. Well i have to finish the under carrage and assemble the chassis and figure out what im going to do about the side glasses. �� that is going to take some head scratching
Old 03-24-2014, 11:32 PM
I have made a net for the inside. Up next i will do the window net
I miss looked at where the net part of the window net was. So i remade both the inner and outer nets.
I cut a section of seat belt decal off of set to mimic the stitching.
A few trinkets for the engines
Thanks for watching
