Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 02-25-2014, 06:49 PM
nathyrin nathyrin is offline
Question 90's suburban Ignition, electrical, fuse problems?
My Suburban has been dormant for about a month because of a bad starter/cold weather. The starter was removed from the vehicle and the battery disconnected (Via the negative post) the entire month. I decided to replace the starter, hooked everything back up including the battery and I only have headlights, no other power to the vehicle. Any ideas? It did have a security system installed, but never worked since I've owned the vehicle. Please help me. I need my truck!
Old 02-25-2014, 07:35 PM
rhandwor rhandwor is offline
Re: 90's suburban Ignition, electrical, fuse problems?
Did you clean the ground wire? Were any fuseable links burned on the wiring to the starter? Did you hook up all the wiring to the starter?
Tags
472 , electrical , ignition , problems , suburban
