Old 06-24-2003, 07:34 AM
Hybrid93Hatch Hybrid93Hatch is offline
Send a message via AIM to Hybrid93Hatch
How to wire secondaries Eg/GSR Hybrid?
I tried all day to wire my secondaries up in my Eg/GSR.
The car would not start because the 15amp ECU fuse was blown. Still can't get the secondaries to work.
WHAT I TRIED SO FAR:
1) Black IAB wire to B1 at obd1 p72 ECU - blew the 15amp ECU fuse
2) Black wire to junction power harness - blew the same fuse again
93 Civic Cx
98 GSR motor (usdm)
OBD1 p72ECU
I am thinking there is another wire spliced in under the loom / electrical tape to this black wire which I believe is a ground? I spliced in close to the shock tower and maybe need to splice in where the wire comes out the IAB. I've already made 3 cuts in wires that turned out to do nothing right at this point. When I took my Cx harness out I took most of the loom / electrical tape and there were wires spliced in underneath it all. I'm thinking the same is done on this wire causing a short / blowing the ECU fuse.
Here's how I tapped in for 12v. Going to use the same connection, but move the splice down right where the IAB sensor is. This is a source for 12v, right?
2005 TCM Scion xB
Eg / GSR swap is almost complete! Few various Q's with pics inside! Hybrid93Hatch Engineering/ Technical 4 04-13-2003 05:28 PM
Wiring the Eg / GSR up! Pics inside! Help needed! *56k might get 0wn3d* Hybrid93Hatch Engineering/ Technical 3 03-31-2003 02:47 PM
Day 3 working on the Eg / GSR swap **56k stand back about 8 miles** Hybrid93Hatch Engineering/ Technical 4 03-28-2003 04:47 AM
Day 2 working on the Eg / GSR swap (One pic to summarize day) Hybrid93Hatch '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 5 03-15-2003 09:53 AM
