Go Back   Automotive Forums Car Chat > Buick > Regal
Old 02-22-2014, 10:36 PM
johnholl johnholl is offline
Question groaning noise when steering wheel is rotated
2002 regal LS 3800 V6
steering makes a groaning sound in either direction, even when not moving.
ps: looks like a bitch to access the pump
John
Upstate NY
Old 02-23-2014, 11:06 AM
Tech II Tech II is offline
Re: groaning noise when steering wheel is rotated
Well, the first thing you want to do, is check the fluid level........if ok, then leave the cap off, and have someone start the car and turn the wheel side to side......if you see a lot of air in the fluid, you have a leak somewhere and air is getting into the system, causing this noise.....could be the pump, lines(especially at the crimps), or the seals on the rack(the bellows on the ends of the rack will be filled with fluid).....
If you have to replace the pump, remove the metal line first, then the rubber return line....serp belt.....then just two bolts......get a replacement pump with a pulley....otherwise you will have to rent/buy a pulley remover to transfer the old one to the new one....
Old 02-23-2014, 03:44 PM
my next question is which side of the engine is the reservoir located. Some say firewall-side, some say radiator side. it is a Regal LS with the 3800 power plant.
Old 02-23-2014, 04:32 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
The power steering pump resivoir is on the power steering pump.
Old 02-23-2014, 05:27 PM
The cap with the level indicator under neath it, is screwed into the reservoir....the reservoir is that black plastic tank on top of the pump....
Old 02-23-2014, 06:01 PM
ops, sorry....i know the reservoir is on the pump. which side, firewall or radiator, is the pump mounted?
Old 02-23-2014, 06:51 PM
aleekat aleekat is online now
Not being a sm**tass. But have you popped the hood and looked? Most owners manuals shows a diagram/picture of the motor and common maintenance things that the owner can do himself. Power steering pump is driven by the belt. Look around the belt area and what it is driving.
Post back, that's what makes Forums Work.
Old 02-23-2014, 09:42 PM
Alee, you might be onto something....
