Old 06-24-2003, 12:13 AM
Blackout Blackout is offline
Dechroming
does anyone know how to effectively remove chrome from parts without having to sand them? Is liquid drano an effective tool, or is there something else that works better?
Old 06-24-2003, 12:19 AM
TheSyndicate's Avatar
TheSyndicate TheSyndicate is offline
CSC or bleach.
Old 06-24-2003, 12:21 AM
Jay! Jay! is offline
Horizontally Opposed
Originally posted by TheSyndicate
CSC or bleach.
Hierarchy of Subaru:
(Click to see mine!)
Old 06-24-2003, 12:22 AM
bleech hu? I never thought about that. I always thought that liquid drano did the job. I'll try bleech and let you know how that turns out.
Old 06-24-2003, 12:27 AM
well the bleech doesn't seem to be working too well. What is CSC?
Old 06-24-2003, 12:28 AM
Check the FAQ. It stands for Castrol Super Clean, but it's only available in the US...
Old 06-24-2003, 01:24 AM
008's Avatar
008 008 is offline
You post 5 minutes later and say the bleach isn't working? It'll take longer than that. You have to soak it in for a bit. Don't expect to just instantly wipe the chrome off with a rag like magic. You have to get through the chrome, then you have to get the clearcoating off. Scratch it up a bit with sandpaper before soaking so the bleach has some crevices to seep into.
I used to soak them in "Soft scrub with bleach" before I discovered CSC.
Old 06-24-2003, 05:08 AM
935k3's Avatar
935k3 935k3 is offline
Try Easy-Off oven cleaner(in the yellow can) Ammonia also works except it doesn't remove the clear coat under the chrome. That clear coat can react with some paints sprayed over it. The oven cleaner removes the chrome and the clear coat.
Old 06-24-2003, 05:55 AM
exhaust smoke's Avatar
exhaust smoke exhaust smoke is offline
I use either Mr Muscle oven cleaner or Brake fluid
Old 06-24-2003, 08:21 AM
thanks for the advice. I'll give the CSC a try today and hope that works.
Old 06-24-2003, 08:38 AM
Guido Guido is offline
And it's done in 5 minutes! Did another set of wheels last weeks and a couple of Mercedes grills as well. Easy stuff.
Old 06-24-2003, 08:57 AM
mech0t0's Avatar
mech0t0 mech0t0 is offline
This is an outdoor task! Wear protective gears please! Raise all part with soap and water when all crome is removed!
Hope that helps!
