Old 06-23-2003, 10:57 PM
streetdreams420 streetdreams420 is offline
Send a message via AIM to streetdreams420 Send a message via MSN to streetdreams420
relocating battery
okay question I relocated my battery and ever sense my battery dosen't seem to charge as fast or as much, I have a volt meter and before when the battery was under hood the gauge was always around like 14 when car was not running/ now that I relocated it, it sits at like 12 and goes to like 14 after the car is running for a bit, anyone no wtf??oh ya same battery never changed and i'm running 4 gauge wiring
Old 06-23-2003, 11:16 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
4AWG might be to small, I know I used 2AWG on mine and it works fine.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 06-23-2003, 11:18 PM
relocating battery
thanks bro i'll give that a try can't hurt any to put in bigger wire hopfully it works
Old 06-23-2003, 11:29 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Yeah, I wouldn't run anything smaller than 2AWG which is what I used to relocated the battery...
One thing though is that when the car is off, it's supposed to measure around 12V, and when you turn the car on, the voltage should be around 14V, so it's probably not a problem that you need to worry about.
Another thing you may want to do (which I did) was run heavier guage wire to the starter and alternator...
Old 06-23-2003, 11:58 PM
relocating battery
thanks again ci5ic thats the second time today you have helped me out, i'm going to say fuck it and use my 4 gauge for all the wiring like starter and shit. and just get 2 guage for the battery, oh ya when I had the battery under the hood the gauge stayed just under 14 even with the car off, but I know what you mean
Old 06-24-2003, 12:01 AM
ci5ic's Avatar
Re: relocating battery
Now that I think about it, it could also depend on where you're measuring the voltage from...
Since you had the battery up front, the wires were relatively short, but by increasing the length of the primary wire, there may be some additional resistance which would cause a difference of voltage depending on where you put the volt-meter probes... Just for fun, turn the car off, check the voltage in the engine bay, then check the voltage in the back at the battery, then do the same thing with the engine on and see how much the voltage readings differ from front to back... I'd be curious to know, I never bothered to measure mine.
Old 06-24-2003, 12:04 AM
Stali08's Avatar
Stali08 Stali08 is offline
Send a message via AIM to Stali08 Send a message via Yahoo to Stali08
how about the path the wire takes, like if it would take a lot of twists and turns and not just a straight path, would tha effect the voltage?
PeacE
Old 06-24-2003, 12:07 AM
relocating battery
good call ci5ic I never thought about that and I did run a whole new wire to the battery and it's like three feet longer, i'm gonna check that out tommorrow,
Old 06-24-2003, 12:18 AM
ci5ic's Avatar
Not likely... If there was a big coil in the wire, it might act like an inductor, which would affect the voltage a little, but not enough to really do anything...
Where did you relocate the battery to? I was under the impression that you relocated it to the back of the car, but an extra 3 feet of wire isn't enough to get back there, so I'm a little confused.
Old 06-24-2003, 12:22 AM
91civicDXdude's Avatar
i relocated the battery to the hatch and used 4 gauge wire.. i've never had a problem.
I used my 4 gauge amp wire that was already ran, hooked the battery to the rear end of it, and used one of those stereo setup "power splitters" and ran 8 gauge wire to my fusebox and starter.
Old 06-24-2003, 12:23 AM
ci5ic's Avatar
That's pretty much what I did, but I used 2AWG Accel wire from Summit Racing and a 0AWG ground. Ran the 2AWG to the starter and the alternator too... starts easy as hell.
Old 06-24-2003, 12:26 AM
relocated battery
sorry ci5ic I ment it is like 3 4 feet longer then what I had before lets say its like 7 feet full just guessing
Old 06-24-2003, 12:42 AM
Trancebot's Avatar
Trancebot Trancebot is offline
Send a message via AIM to Trancebot
since you guys are on the subject i was wondering does relocating the battary to the rear on a fwd car help performance in the twists with out sacrificing traction?
i assumed that's why you guys relocated for better weight distrubtion?
1968 camaro in the works but once it works oh man will it work.
1993 cbr600f2 got crotchrocket?
Old 06-24-2003, 12:55 AM
I have about the most detailed write up about this on my site that you will find anywhere...
http://www.fourthgenhatch.com/battery.html
Old 06-24-2003, 01:46 AM
XxLuckyLisaxX's Avatar
XxLuckyLisaxX XxLuckyLisaxX is offline
Send a message via AIM to XxLuckyLisaxX
damn dude you have hella how-tos on your site, i didnt look at any of the others did you write them all up yourself? if you did mad props dude for real everyone should check it out
Keep it real, and share the knowledge.....
Say NO to Primer!!
