Go Back   Automotive Forums Car Chat > Mercury > Mystique
Old 02-17-2014, 08:30 PM
lionheartsails lionheartsails is offline
Radio, Interior Light and Power Mirrors don't work
1999 Mercury Mystique V6-2540 2.5L DOHC
I just replaced The Fuel Pressure Sensor on the Fuel Rail and the Washer Pump, now I have electrical issues.
I don’t how they could be related but began the first time I started the car afterwards.
The following electrical items do not work:
Radio
Key-less entry remote
Power Mirrors
Interior Light
The sensor that prevents you from removing the ignition key unless in park
These are the things I have found so far.
I saw another post on this issue from 2010 with no replies
Old 04-17-2014, 10:59 AM
Re: Radio, Dome Light and Power Mirrors won't work?
With a meter, I have have physically check all the fuses in the Power Distribution Box (under hood) and Passenger Compartment Fuse Panel.
Fuses 29, 31, 33, & 35 have no power on the (+) side of the fuse block (lower bank of passenger compartment fuse panel.
Any Idea? I have looked over previous posts and have found issues with a wiring recall but that appears to be associated with earlier models.
Old 10-18-2014, 12:39 PM
OBS49 OBS49 is offline
Check and see what kind of fuse you have on slot 34 in the passenger compartment fuse panel, if it's a brown 7.5 amp take it out and insert a yellow 20 amp.
In my case that solved it.
If that is not your case then I'm clueless.
