Old 02-17-2014, 07:18 PM
daviejj daviejj is offline
Help on setting timing
Does anyone have a diagram on 1997 S10, 2.2 timing settings? If timing is off, will the engine sound as if the bearings are knocking somewhat? I installed a new crankshaft and new bearings. Also do the ignition coils usually go bad? Should the #1 cylinder be on the compression stroke?
Thanks for the help
Ron
Old 02-18-2014, 08:50 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Help on setting timing
Thanks for the help
Ron
The dot on cam gear should be straight down toward the crank gear with the crank gear dot straight up. : Right to-wards each other :
If the timing chain is off it could bend valves and rockers.
Some engine are on opposite firing cylinder when timing chain is set on timing set up.
MT
Old 02-18-2014, 07:03 PM
Thank you MT for the info. Another question, does the #1 cylinder have to be on top dead center to set the timing?
Old 02-19-2014, 10:22 AM
MT-2500's Avatar
AF - Advisor
It has no dist..
And no timing adjustment setting.
Timing is controlled by computer.
Just get the timing gear marks lined up.
AND YOU ARE SET TO GO.
MT
Old 02-19-2014, 06:46 PM
Many thanks for the info MT.
