Go Back   Automotive Forums .com Car Chat > Oldsmobile > Bravada
Old 02-14-2014, 11:20 AM   #1
scottc7324
97 bravada with a sputter
I have a 97 bravado that at idle will sputter and at take off will do the same thing, but once I get going it goes away and is fine. I did a complete tune up on it as well as replaced the idle air control valve, the tps sensor and the egr valve and it still does it. any suggestions what it might be. anything would help at this point.
scottc7324 is offline   Reply With Quote
Old 02-14-2014, 06:27 PM   #2
Chris Stewart
AF - Advisor
Chris Stewart's Avatar
Re: 97 bravada with a sputter
Is the Check Engine light on?
Look at all the vacuum hoses and check for cracks.
You might check for loose bolts holding the intake manifold to the engine.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Chris Stewart is offline   Reply With Quote
Old 02-14-2014, 06:40 PM   #3
scottc7324
i have not checked for a vacuum leak yet. there is no light on because the person i got it from either pulled the bulb or it is burnt out. when i turn on the ignition the check engine light does not come on and for that i was told that the scan tool will not bring up a code if no bulb is in it. i went to 3 different parts stores and all 3 said the same thing. any particular line i should check for a leak. i mean is there one that tends to leak the most.
Old 02-14-2014, 10:08 PM   #4
Tech II
Have it checked for codes......bad light bulb has nothing to do with whether a code has been set....
Tech II is offline   Reply With Quote
Old 02-15-2014, 07:52 PM   #5
Chris Stewart
AF - Advisor
So the Check Engine light bulb being out won't keep a code reader from retrieving any codes stored?
Old 02-15-2014, 09:07 PM   #6
Tech II
No it won't.....
