Old 02-13-2014, 07:38 PM
scheppster scheppster is offline
Turn Signal light trouble
The left turn signal light inside care stays on and outside front left light the rear light does not. when I turn the lever down rear comes on but nothing flashes. Right side working fine. ???????????
Old 02-13-2014, 08:30 PM
Re: Turn Signal light trouble
Could it be a corroded bulb
Old 02-13-2014, 08:38 PM
Tech II Tech II is offline
Bad bulb/socket?
The Following User Says Thank You to Tech II For This Useful Post:
scheppster (02-13-2014)
Old 02-14-2014, 07:12 AM
Question Re: Turn Signal light trouble
I just pulled bulb out and left turn signal indicator inside car stays on
Old 02-14-2014, 07:18 AM
imidazol97 imidazol97 is offline
AF -Advisor
Did you pull both the front and rear bulbs that are the brake/turn signal?
I believe the side marker bulb may be involved in the circuit as well. Look for those and check them.
The Following User Says Thank You to imidazol97 For This Useful Post:
scheppster (02-14-2014)
Old 02-14-2014, 08:01 AM
Wink Re: Turn Signal light trouble
thanks I will check, I know side marker light is out . didnt know it was all connected.
