Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 02-08-2014, 08:14 PM
akarthik akarthik is offline
2007 Camry LE key
Hi,
I am new to this forum. Before posting this thread I did my homework going through the FAQ's which directed me to the service manual link which did not exist(coz of shutdown of site). Coming to my question - My master key shell is broken and I am planning to get it replaced. I found that if I can just buy the key shell(from amazon or ebay - which doesn't have the chip inside) and move the internal component of the master key to the new key and get it cut by locksmith, it works. Is this true?
Also, if I, for say, buy a new key (with chip inside it), can I program it myself? If I did program - will it be used for the ignition too or is it just for the lock, unlock buttons to work?
Thanks
Old 02-08-2014, 11:58 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 2007 Camry LE key
Sorry, I can't help you with the key, but I can help you get a service manual. Send me your e-mail address by PM.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 02-09-2014, 12:24 AM
I am unable to send a PM to you, for some reason.
Old 02-09-2014, 01:04 AM
Brian R.'s Avatar
Resident Chemist
Check your e-mail
(FYI, you sent me many PMs)
Old 02-09-2014, 07:50 PM
ukrkoz's Avatar
ukrkoz ukrkoz is offline
Good locksmith should be able to flash a new key with chip so that it works for your vehicle.
I have 07 Camry but mine is push start button.
There is also key learning procedure for a new key. Likely in manual, or simply Google it.
Your new shell with original chip inside should work just fine. If it's not damaged.
Tags
2007 , camry , key , program
