Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 02-07-2014, 03:32 PM
TCHRISD TCHRISD is offline
Problem with heater....
I have a 98 1500 V6....120K. It has had an issue with the heater since I bought it over a year ago. It would not reach normal running temperatures and heater would not get hot. I have recently replaced the thermostat (195°). Which helped get it closer to reg temps, but still not there (between 150-170).
Is this a heater core issue?
Any help is appreciated........
Old 02-07-2014, 05:32 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: Problem with heater....
Most likely.
If any stop leak has been used, it'll collect on the heater core also because of the slow water flow going through it.
I have a similar problem with my Olds Bravada and if it warms up tomorrow, I'll flush mine with the garden hose.
I'll take both heater hoses loose from the engine, slowly apply pressure to one heater hose with the garden hose, flush until it becomes clear then swap to the other heater hose and repeat.
I won't connect the garden hose to the heater hose with any clamp, just slowly put them together so's not to apply too much pressure. Most home water pressure can easily burst the heater core, go slow with a weak stream.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
