Old 02-04-2014, 11:15 AM
mno221 mno221 is offline
check engine oil level
I just change my oil last night and this morning my check engine oil level is on and my oil dipshows the correct amount of oil, what can be the problem?
Old 02-04-2014, 11:26 AM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: check engine oil level
Probably a problem with the oil level switch, or the wiring to it.
The Following User Says Thank You to gmtech1 For This Useful Post:
mno221 (02-04-2014)
Old 02-04-2014, 01:58 PM
j cAT j cAT is offline
check the connection to the sensor.
Old 02-14-2014, 11:14 PM
Thanks guys, replaced the oil level switch and all is well, now just need to figure out where this oil leak is coming from, may have to change my oil pan gasket.
Old 02-15-2014, 07:01 AM
rhandwor rhandwor is offline
Look at your front and rear main seals before you do the pan gasket.
Old 02-24-2014, 04:23 PM
he had a bad switch ...........
