Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 02-01-2014, 01:02 PM
studdly studdly is offline
98 corolla oil
does anyone else notice that the 98 corolla seems to go through oil? not burning it or and leaks. I have talked to another person with a 99 and he is having the same problem. the engine only has 136,ooo kms on it. any ideas???
Old 02-02-2014, 01:54 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 98 corolla oil
How often do you have to add a quart of oil to maintain the dipstick level? How do you know you're not burning oil?
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 02-02-2014, 04:01 PM
Re: 98 corolla oil
got a mechanic to check and no oil burning. I add a liter once a month
Old 02-03-2014, 08:20 AM
Brian R.'s Avatar
Resident Chemist
Re: 98 corolla oil
How did he determine that you're not burning oil? If you burn 1 liter a month, you would have a difficult time figuring this out, the more miles you drive, the more difficult it becomes. If you're sure you don't have leaks, then you are burning it. It doesn't evaporate. Leaks are much easier to discover than burning.
Old 03-22-2014, 11:19 AM
kimper kimper is offline
Re: 98 corolla oil
my 02 corolla was burning a quart every tank of gas and it ended up being that the oil drain back holes in the pistons were plugged and my rings were stuck and it was forcing the oil up into the valves. It was so bad that the carbon build up was preventing the valves from seating all the way..
