Old 01-30-2014, 11:44 AM
cwargo cwargo is offline
no spark again
Here we go again. shut my 87 F150 5.0 off when I got to work when it was time to leave no spark from the coil ,same as 3 weeks ago .First thing I did was pull the new dist and replace it nothing,so I pulled out the new coil still nothing ,its getting power to the coil so I would assume the relay is good . Any other ideas .
Old 01-30-2014, 12:30 PM
mechhound mechhound is offline
Re: no spark again
I assume the ignition module mounted on the side of the distributor was also replaced with new, and not reused, this morning?
The ignition module is always the first thing I suspect in a total no start, no intermittent, condition.
Old 01-30-2014, 01:38 PM
Re: no spark again
new module came with the dist
Old 01-30-2014, 01:59 PM
Re: no spark again
I'm stumped. Unless the NEW distributor you got this morning was also bad. I assume you remembered to plug in all the electrical connections?
There is always talk of a bad ground causing this condition, but I personally have never experienced this condition.
Old 01-30-2014, 05:58 PM
Re: no spark again
Yea I was told the same thing , I quess I'll try to run some ground wires and see what happens .
