Old 01-29-2014, 09:58 AM
wseeloff wseeloff is offline
99 F250 SD acting up
My speedometer is erratic, not reading correctly, and the trans is not shifting right. It gets up to 3000 RPM and I have to back off the throttle to make it shift to 2nd. Then after driving a while everything starts working right. Next time I drive the truck it does the same thing. Any ideas?
Old 01-29-2014, 11:38 AM
jyount jyount is offline
Re: 99 F250 SD acting up
I believe the speed sensor is on the top of the rear differential. It probably has something stuck on it or it needs replaced. If shifting and speedo related almost 100% it has something to do with a speed sensor.
10 hours away from John Deere master certified
also master certified ASE tech. Exp. in both.
Went to school for cars, wound up staying with Deere dealer for a while, so schooling there too. Also couple years exp in GM and some GM training
Gave up wrenching for "Greener Pastures"
Current job: RN
2010 Silverado Z71 5.3L 65xxx
Wife's
2007 Suburban 1500 LTZ 5.3L 102xxx
Old 01-29-2014, 11:54 AM
Thanks for the help. Too cold to change it right now but when I do I'll post where it worked or not.
