Old 01-27-2014, 02:06 PM
parkerb parkerb is offline
upper radiator hose drooping
hi all,
my '02's upper radiator hose is drooping, enough that the nylon mesh netting wrapped around the hose for protection [around the battery] has worn a cut from rubbing on the battery tray (the hose isn't cut, just the outer protective weave).
the '00 does not have this problem, and they are both original hoses. anyone had this? is something imminent (time to replace the hose)?
tia,
parker
Old 02-05-2014, 05:56 PM
wiswind wiswind is offline
Re: upper radiator hose drooping
If in question.....I would replace it.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 02-05-2014, 07:46 PM
12Ounce 12Ounce is offline
It may work better swapped end-for-end. If I remember correctly, that hose is almost identical on each end ... but not exactly.
Old 02-26-2014, 09:57 AM
one end says "RAD" on it. came from ford with the clamps too.
i finally got around to replacing it last night. since the hose is ~20" long with 3 90 degree bends, if you don't orientate the "RAD" end correctly, or twist it (torsion) creating lift for the middle length of the hose, then it will droop.
hth,
parker
