Go Back   Automotive Forums Car Chat > Ford > E Series
E Series Forum covers questions and discussions regarding Ford E-150, Ford E-250, Ford E-350, and Ford E-450.
Old 01-26-2014, 12:29 PM
w4zzk73 w4zzk73 is offline
E350 Brake Light Issue
Hi All
I'm dealing with a 2006 Ford E-350 XLT Superduty
Odd thing happening with my brake lights...
They do not come on when the brake is pressed. I have turn signals, Hazards, and tail lights when I pull on the head/tail lights. I have checked the brake switch at the pedal, and voltage is present where it should be.
Any ideas?
Thanks a bunch.
Old 01-26-2014, 12:54 PM
mechhound mechhound is offline
Re: E350 Brake Light Issue
It could possibly be in the multi-function switch. You might try flicking the turn signal lever up and down several times just for the heck of it to see if that helps.
I really hope someone else replies here, saying what they think.
Old 01-26-2014, 01:00 PM
OK. For what it's worth, I can shift in and out of park as normal... I had been told if you could not shift out of park, it would be one issue... if you could, it would be another issue. I'll go play with the MFS for a while and see what happens.
Old 01-26-2014, 07:13 PM
DeltaP DeltaP is offline
" I have checked the brake switch at the pedal, and voltage is present where it should be".
Does the switch pass voltage when the circuit is closed? Recheck switch then multi function switch.
