Old 01-24-2014, 04:28 PM
gnorthey gnorthey is offline
'02 Bravada
Hello,
I've searched and did not find the answer to the question I was looking for so hope you may be willing to share...
I have a 2002 Olds Bravada with the air suspension system. I would like to convert to variable rate springs and do away with the air bags. Would anyone know if the standard coil springs from a Blazer of the same year would swap in for the Bravada if I removed the air bag and springs that are in there now?
Thanks in advance.
Old 01-24-2014, 06:10 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: '02 Bravada
I'm gonna say no. The frame mounts, where the top of the air spring sits, is different than the coil spring set up, the coil springs will not sit correctly and are probably different lengths also.
Old 02-10-2014, 04:04 PM
Re: '02 Bravada
Right. I went with the kit from Westar. Took me longer to remove the tires. Little pricey for a couple of springs but the ride is nice.
Thanks!
