Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 01-24-2014, 11:08 AM
magpi1 magpi1 is offline
temp gauge and heater
ford crown vic, 1999, 125k miles, no engine work has been done,did flush cooling system in spring of 2013 and put in a 50/50 mix of coolant and distilled water (from a jug). No problems for the summer of 2013, have been using heater with no problems until around Tuesday of this week.
Car runs fine, no leaks, coolant checks out good. BUT now..
My temperature gauge hardly moves (up) and the heater blows warm air only.
If I am driving the gauge will not move, if the car sits running for awhile it will move up some and the heat will get warmer inside of the car.
My guess maybe a stuck thermostat? Anyone ever had a problem like this?
Thanks to any and all help.
Old 01-24-2014, 12:08 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: temp gauge and heater
Sounds like you are on to something with the thermostat. I'd replace the stat and see what happens.
Especially if it has not been done recently.
The Following User Says Thank You to gmtech1 For This Useful Post:
magpi1 (01-28-2014)
Old 01-25-2014, 02:23 PM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
It's a stuck thermostat. Buy a new t-stat for your year of car (I believe a 192 or 194 degree) and install. Shouldn't take more than 15 minutes.
Do NOT over tighten the bolts on the t-stat housing. The polymer intake manifold coolant crossover can crack and then you'll have to replace the whole thing.
IIRC, they should be tightened to the same torque as the spark plugs.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
The Following User Says Thank You to Blue)(Fusion For This Useful Post:
magpi1 (01-28-2014)
Old 01-28-2014, 01:09 PM
((((UPDATE))))
Yeah, It was the thermostat. Put a new one in yesterday, tested it real good today and had no problems.
Thanks to all who helped.
