Go Back   Automotive Forums Car Chat > Mercury > Sable
Old 01-18-2014, 07:36 PM
cdn navy cdn navy is offline
AC Compressor Running?
I suspect that the a/c compressor on my 1999 Mercury Sable is running even though the a/c switch on the dashboard is in the off position. Does anybody know how to determine if it is in fact active?
Thanks
Old 01-19-2014, 09:07 AM
DeltaP DeltaP is offline
Re: AC Compressor Running?
Yeah, open the hood and look at the a/c compressor with the engine running and a/c controls off! The front pulley,with the belt going around it will be turning and the front hub of that pulley will be stationary if the a/c is off. HTH
Old 01-19-2014, 09:34 AM
aleekat aleekat is offline
Most cars, if you are in the windshield defrost mode, the a/c runs.
Post back, that's what makes Forums Work.
Old 01-19-2014, 10:14 AM
And that too. But if the a/c is in the off/off position that will eliminate that as well.
Old 01-19-2014, 01:02 PM
I checked to see if the front hub of the compressor is turning and in fact it's not. I double checked by turning on the a/c and found that it still does not turn. It's cool outside, so I'm not sure if that has anything to do about it or not. I suspect not.
The reason I think the A/C is running is because after I park the car, there is a puddle of water (not coolant) under where there a/c is located.
Any thoughts?
