Old 01-16-2014, 02:02 PM
aieridis's Avatar
aieridis aieridis is offline
Paint booth for zero paints
Hi everyone,
Is there anyone that can recommend a proper spray (paint) booth for toxic paints such as the Hiroboy Zero Paints?
Thanks a lot
Alex
Old 01-16-2014, 02:10 PM
CFarias's Avatar
CFarias CFarias is offline
Re: Paint booth for zero paints
Any paint booth that can give you 0.4 to 0.5 meters/second across its opening should be adequate, provided that it exhausts to the outside or into a charcoal filter.
it should also have a filter to protect the exhaust fan.
You'll find a great deal of discussion on this topic by searching the site. Also, building one yourself is not as difficult as it sounds once you understand how they work.
Hope this helps.
The Following User Says Thank You to CFarias For This Useful Post:
aieridis (01-17-2014)
Old 01-16-2014, 02:59 PM
Hemi Killer Hemi Killer is offline
I made my own. It's not fancy but it works. I used white posted board from the crafts store, cut it to the sizes I needed and duct taped it together. Then I got an 80 cfm bathroom cieling fan and cut a hole in the back of the booth and set it in. Then I hooked up the ducting, which goes out the window when I paint.
The Following User Says Thank You to Hemi Killer For This Useful Post:
Old 01-16-2014, 05:51 PM
stevenoble's Avatar
This is the one I'm using below. You can make your own, but I went for a purpose built one from day one and have never regretted it. I would say it's the best modelling related purchase I ever made. I spray Zero paints and lacquers with absolutely no smell whatsoever, so as you can imagine it's a very pleasant working environment. I've had it for a number of years and it comes with a lifetime warranty too. The only slight drawback was the cost of the filters at around £14 each. However I have now sourced two rolls of the exact same material that the filters are produced from, in fact the stuff I've bought is slightly better quality. One is the glass fibre 'paint stop' netting, the other the fabric 'scrim' that fits behind. I now make my own filters straight off of the roll. The cost..?? Around 30 pence for a filter change. I've calculated that the two rolls should last nearly 13 years and that's with 6 filter changes per year. Anyway picture below. It's the Graphic Air A300S-D. The 'D' is for ducted. You can pass the duct through an open window or plumb it in permanently, it's up to you.
Link to website
http://www.graphicair.co.uk/products...ray-Booth.html
A300S-D
Steve Noble
The Following 2 Users Say Thank You to stevenoble For This Useful Post:
aieridis (01-17-2014), neo_virus (01-24-2014)
Old 01-17-2014, 02:54 AM
Steve, does it use carbon filters? How often do you need to change it?
Old 01-17-2014, 04:46 AM
John18d John18d is offline
Wow Steve - your work place is as impeccable as your model building.
I'm embarrassed to say my work place is an absolute mess.
Did you ever see the picture of Einstein's desk??
that's my work place. - lol
Cheers
John
The Following User Says Thank You to John18d For This Useful Post:
Old 01-17-2014, 05:03 AM
stevenoble's Avatar
No it doesn't use carbon filters, but you can get carbon filters if you desire to. It uses a two stage filter. The first stage is a fibre glass 'paint stop' material, which traps any wet paint and the bulk of the over spray. Then there is a second denser layer of material which filters out anything that is left. The filtered air is then exhausted through the long grey pipe to the outside, either through an open window, or you can plumb it in for a more permanent fixing..
Steve Noble
aieridis (01-17-2014), Hemi Killer (01-17-2014)
Old 01-17-2014, 12:45 PM
aieridis's Avatar
thanks a lot guys, all the info is very useful. I am thinking to buy the Graphic Air one, probably...
Old 01-20-2014, 03:01 AM
UKPonchoMan UKPonchoMan is offline
Steve,
Could you advise where you got the replacement filter material from - sounds like it would save us all a fortune!
Chris
