Go Back   Automotive Forums Car Chat > Ford > Expedition
Old 01-16-2014, 11:24 AM
exitRooster exitRooster is offline
2007 outside pull door handle failure
H ey, I'm on my way into work, but this morning I went to open one of my rear passenger doors and the handle just pulls freely. Door is unlocked and opened fine from inside.. what could this be, and is it something I can repair fairly easily, or might it be under warranty as I have the warranty still..this a common problem, seems unusual to me :-( thanks in advance for any input on the matter!
Proud owner of:
1995 Oldsmobile Cutlass supreme convertible (3.4l, black/black)
SOLD BUT STILL ON ROAD! (1995 Mercury Villager (3.0l, 200k+ miles and still going))
2006 Ford Escape XLT
2002 Oldsmobile Alero (3.4l)
2007 Ford Expedition (5.4l, EB EL, 1st Ford since my LTD-II ROFL)
Old 01-16-2014, 11:56 AM
65comet's Avatar
65comet 65comet is offline
Re: 2007 outside pull door handle failure
Ask first if it is under warranty. They could repair it and afterward say it isn't covered.
Now, on to the problem. The usual failure is the inside handle, not the outside. The inside connects via a cable and the top connection of the outside cable sleeve will either pop out of the connector of the large plastic frame or the connector ears of the large plastic frame will snap off and the outside cable sleeve moves with the inside cable so that no movement occurs at the lock. I didn't pay a lot of attention to the outside handle when I had mine open, but they are usually just a thin solid push rod connected to the handle and the lock mechanism. The rod can move out of one of its connectors, it can bend and one of the plastic connector ends it pops into can break apart. So the door panel needs to come off to see what the problem actually is.
