Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 01-14-2014, 11:05 AM
thegreenhornet95 thegreenhornet95 is offline
radiator swap
Will the radiator from a 1994 Sierra fit in a 1995 suburban and vice versa
Old 01-15-2014, 07:53 PM
kenman1717 kenman1717 is offline
Re: radiator swap
yes and no. they will interchange no problem, but I have ran into a few if the engine size is different the radiator width is a bit different, therefore the shroud is a little different, but everything will still bolt in the proper locations, and also with this swap watch rad hose length.
Old 01-18-2014, 09:55 PM
Re: radiator swap
I decided to buy a new one and still ended up with the wrong one. mine is much larger than the one i bought can my truck be older or newer than it says Autozone said it's the one for my truck.
Old 01-21-2014, 05:23 PM
rhandwor rhandwor is offline
Re: radiator swap
Usually the Manufacturing date is on the drivers side door. I would give Auto Zone the measurements talk to the manufacturer.
Old 01-21-2014, 09:25 PM
Re: radiator swap
Got One!!! Its not. running hot but now. my upper hose is cold and lower is hot
Old 01-22-2014, 04:46 AM
Re: radiator swap
I'm glad its not running hot. Normally after the truck is up to temperature it will have circulation and both hoses will be warm after the thermostat is opened.
