Go Back   Automotive Forums Car Chat > Ford > General Discussion
Old 01-11-2014, 02:14 PM
CREWZN CREWZN is offline
Is it possible
I have a leak on a rusted transmission cooling line and wondered if you can replace it all with rubber instead of the steel lines that are there? Is there any down side to that. It appears a replacement part is $82 and the hose is about $8. I just don't wish to bugger up the transmission. Any views would be appreciated.
Old 01-12-2014, 10:43 AM
brcidd's Avatar
brcidd brcidd is offline
Re: Is it possible
Yes, they make tranny cooling hose- done it many times. rubber does not corrode.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
The Following User Says Thank You to brcidd For This Useful Post:
CREWZN (01-13-2014)
Old 01-13-2014, 10:53 AM
65comet's Avatar
65comet 65comet is offline
Re: Is it possible
Make sure it is a rubber that can handle tranny fluid. Some will allow tranny fluid to penetrate in and soften as well as expand the rubber. Then it will just blow apart if it has any pressure in it. That is why brcidd said "they make tranny cooling hose". I can't remember which rubber hose is an absolute no, no when it comes to that. I know I've used anything just to get home in an emergency, then immediately bought the correct hose material.
Old 01-13-2014, 06:37 PM
DeltaP DeltaP is offline
Re: Is it possible
These guys are right. It must be a neoprene lined hose like power steering hose. Any other rubber hose will soften,swell,leak and burst under pressure... in that order. Like 65comet said any hose can be used temporarily in an emergency. But ya need to change it soon before you forget about it.
The Following User Says Thank You to DeltaP For This Useful Post:
CREWZN (01-14-2014)
Old 01-14-2014, 06:34 AM
Re: Is it possible
Thank you all for your responses. I was able to get transmission rubber , disconnected the line, did a clean cut, flared the end and put in the rubber tube with a brass hose connector. Worked great, thank you all that responded.
