Old 01-10-2014, 05:03 PM
broughy84's Avatar
broughy84 broughy84 is offline
92 c2500 heater control problems
I have a 92 c2500 cheyenne. It's just a base model nothing special work truck with a 4.3 and 198k on it. The problem started yesterday after I replace a battery that the cold weather zapped.
Let me start out by saying the heater controls function fine. When I reconnected the battery, immediately my a/c clutch engaged. I started the truck and turn the heat/ac panel off and it disengaged. Not trusting it, I unplugged it, as I need my truck to start in the mornings to go to work! So I drive to the store last night and shut the truck off and the heat controls stay on as does the blower fan! I reached over and hit the power button and the fan and display went off. I didn't think a bunch about it.
Tonight on the way home from work it did it again. I drove around town then shut the truck off and it did it again. SO I pushed another button to see if it would switch vents and it shut off. I'm puzzled!
Has anyone ever had anything like this happen to them? I AM BAFFLED!!!
Matthew Brough
1997 Geo Prizm -- 301,000 miles
2000 Honda Accord -- 225,000 miles
2004 GMC Yukon XL -- 223,000 miles
1987 Jeep Comanche -- 116,000 miles
Old 01-10-2014, 06:43 PM
777stickman 777stickman is offline
Re: 92 c2500 heater control problems
Try disconnecting the NEG batt cable for 15-30 mins. Just a thought.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 01-11-2014, 01:57 AM
Schurkey Schurkey is offline
If the heater control in the dash is anything like the one in my '88 K1500, they seem to be cold-sensitive.
When I bought the truck, the heater control was so goofy I pulled it apart, and re-soldered the main connections. Many had cracked, they conducted intermittently. Re-flowing the solder made the system much more reliable.
When the ambient temperature is below freezing, I often have to push on the display to get it to light up and function. Yet another cracked solder connection, I suppose.
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
Old 01-11-2014, 01:25 PM
broughy84's Avatar
A little more information on this issue. This only seems to happen if I have the defroster on ( or the a/c ). I'm assuming since the air conditioning compressor is activating as soon as a connect the battery, my issue is a relay issue and it's back feeding power to the control cluster. SO, does anyone know where the a/c relay on this is?
Matthew Brough
Old 01-11-2014, 02:43 PM
broughy84's Avatar
Found the issue. Checked for voltage at the relay behind the glove box. Terminal 87 ( going out to the ac system) had 12 V on it. So did the pressure switch on the condenser. So I tracked it in between the two. There is a 3 conductor plug in under the dash ( Red, Dk Grn. and Grn) This had melted between the red and the light green connector. Cut the connector out, wired it together and all is well. Thank you all for the help.
Matthew Brough
