Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 01-04-2014, 11:12 AM
1998Dge 1998Dge is offline
Chevy Tahoe cranking probs
Need advice. Have a 1996 Chevy Tahoe (305) Engine having engine cranking problems. It makes a slight grinding noise when normally starting. But sometimes it the noise is loud and seems to lock or seize during cranking. I tried shimming it without success, the gear even stuck in the flywheel. I had the starter rebuilt when the bendix stopped engaging the flywheel. I bought this PU second hand and the flywheel cover had been removed as if this truck has had existing starter problems. Also the flywheel teeth look ok. Any suggestions will help. Thanks in advance.
Old 01-04-2014, 12:02 PM
rhandwor rhandwor is offline
Re: Chevy Tahoe cranking probs
Are all the bolts in the flywheel I've found them loose or cracked but not often. Look at a rebuilt starter are the teeth in the bendix the same diameter.
How many shims did you use this should drop the starter down where the teeth mesh properly. They have only one bolt that goes through the shim the other bolt the shims goes around the bolt but it can be pulled out. I would get three or four and put in one if it still causes noise add another one. Surely it has to work properly. Their is a way you can use a wire and measure between the two gears but I've forgot how to do this. Directions on how to do this are in a rebuilt starter box. I always saved the shims and put in the same amount as I removed.
Will your bolts tighten properly someone may have used a US thread in stead of a metric thread in your case a metric instead of a US I think. A US bolt has hash marks a Metric usually has a number like 9.8 for a GM.
Old 01-04-2014, 10:47 PM
DeltaP DeltaP is offline
Could be a bent flexplate. They have been known to crack through the hub bolt holes where they bolt up to the crankshaft. They'll make a racket! And the ring gear will bind in the bendix gear.
Old 01-05-2014, 09:07 AM
j cAT j cAT is offline
what you need is a new starter . the drive may be re-built , so what about the solenoid ? these electrical devices fail and the drive will not throw or retract properly.
