no start
1999 gmc suburban shut off no start next morning will crank then act's like it loads (cranks hard for a second then back to normal) has good spark has a fuel vapor out of exhaust but will not fire.
What I've checked Spark on every plug. Good and new When I pulled the plugs they were wet with gas Distributer turns new cap & rotor Checked time manually (TDC looked at distributer rotor Pointing cylinderat # 1 cylinder Will check fuel pressure when I get home Thanks for the help Last edited by farmerbudda; 01-05-2014 at 12:31 PM. |
Re: no start
Check for a plugged air filter if clean check fuel pressure.
| The Following User Says Thank You to rhandwor For This Useful Post: | ||
farmerbudda (01-05-2014)
