Old 01-03-2014, 05:18 PM
daviejj daviejj is offline
Brake booster vacuum problems
After replacing the engine, clutch and pressure plate. Please advise where the brake booster hooks up to create a vacuum, as I now have a very hard to push brake pedal, if indeed that is my problem. The pedal will not go down more than one half inch. Thanks to all for the help as I am learning.
Ron
Old 01-04-2014, 07:58 AM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: Brake booster vacuum problems
Ron
What year and engine? There should be a large fitting on the intake manifold or at the base of the throttle body, depends on year and engine you have.
Old 01-04-2014, 09:49 AM
I have a 1997 Chevy S10, 2.2 engine. Would that be the same as you referenced in your quote?
Many thanks,
Ron
Old 01-04-2014, 10:08 AM
gmtech1's Avatar
Hope this helps.
The Following User Says Thank You to gmtech1 For This Useful Post:
daviejj (01-04-2014)
Old 01-04-2014, 11:55 AM
Hope this helps.
Thanks a million. My "SHADE TREE MECHANIC" had the booster hooked to the valve cover. I'm heading there now to check. Ron
Old 01-04-2014, 10:53 PM
DeltaP DeltaP is offline
And he gets paid for this?!?
