Slave cylinder bleeding problem
Hey guys, I'm having trouble bleeding the air out of my slave cylinder or master cylinder in my clutch system any help would be appreciated I've been trying for a couple days now is there a trick to this?
Re: Slave cylinder bleeding problem
Fill the master cylinder with brake fluid and leave the cap off so you don't create a vacuum lock. Open the bleeder screw on the slave cylinder and just let it gravity bleed. Don't let the master cylinder go empty of brake fluid during this process. You are aware of the rubber cup under the cap of the master cylinder lid, that must be removed before filling the master cylinder with brake fluid??
| The Following User Says Thank You to mechhound For This Useful Post: | ||
thunderbirdsc (01-04-2014)
Lol yes I'm aware thanks, yes I tried that with half a little of brake fluid. I'll try again maybe it just takes more time. I'm wondering if I should pull the bleeder right out?
I would just make sure the bleeder valve is not plugged with dirt. I have no idea what you just replaced, if anything.
I replaced slave, clutch, and pressure plate. Well I'll try again. Oh its a90 super coupe.
Other wise if your car is on jack stands one man on the bleeder and another in the car. With the clutch master full of brake fluid pump until you have some resistance open the bleeder. Then if you get fluid go back to the gravity bleed. Or keep going until you get a full clutch pedal allow at least 1/2 hour. If your parts were new I doubt you allowed enough time. |
| The Following User Says Thank You to rhandwor For This Useful Post: | ||
Have you guys heard of firewall flex being a problem on 90s tbird 5spds. Or where to find a brace kit for this..
Manufacturers are reluctant to admit they made cheap vehicles. |
