Go Back   Automotive Forums Car Chat > Kia > Sportage
Old 01-01-2014, 05:29 AM
dilipbaptist dilipbaptist is offline
obd 2 trouble codes for kia sportage 1998 - 02, 15 & 17
Hi
I found these codes for my kia sportage 1998. What could be the problem please. How to fix it....
Cheers
Old 01-02-2014, 01:22 PM
rhandwor rhandwor is offline
Re: obd 2 trouble codes for kia sportage 1998 - 02, 15 & 17
Originally Posted by dilipbaptist View Post
Hi
Cheers
15 is the oxygen sensor.
16 is the EGR valve position sensor.
17 is the feedback system
My scanner would say which sensor is bad as they aren't cheap. I would then delete the codes and check if they returned again.
As Advanced Auto and Auto Zone check codes free check if they can help you.
The Following User Says Thank You to rhandwor For This Useful Post:
dilipbaptist (01-02-2014)
Old 01-02-2014, 06:30 PM
Hi
Thanks for your reply. I cannot understand the code 02 please.
Cheers
Old 01-02-2014, 06:36 PM
Hi
Cheers
I think this means 1998-2002 but I will check further.
Old 01-02-2014, 06:42 PM
Hi
Cheers
2 short flashes is distributor no signal which mean a no start.
2 long flashes is injector no.3 open or short. This would cause a oxygen sensor problem.
Old 01-02-2014, 07:23 PM
They are short flashes. Car starts and runs no problem with that. ????
Old 01-03-2014, 07:57 AM
I never worked on a Sportage and got this from another Kia Forum. On my Kia Sorento I plug in my scanner and it will tell me if I have a code and what it means.
If I was you I would ask Advanced Auto or Auto Zone and check what their scanner says.
I tried years ago to use a plug in tool with led lights,and I would get a 1/2 flash which I was unsure of.
Google Kia Forums and look at a Kia only forum. I'm sure some people have your same type of problem.
Any way check for blown fuses and loose connections or damaged wires for the codes I told you.
Anyway on a Ford I found ignore the 1/2 flash
I checked a Kia forum says its a crank angle sensor.
dilipbaptist (01-04-2014)
Old 01-04-2014, 07:36 AM
Thanks. Can you tell me how many wires are there for oxygen sensor of the same vehicle.
Old 01-04-2014, 10:16 AM
http://www.rockauto.com/ I typed in your sportage and a 4cyl has both upstream and upstream oxygen sensors. the ones I looked at had 4 wires. Two of the wires are for heaters and have 12 volt for this purpose. Use a test light or dvom and check for voltage. If no voltage check for a bad fuse. The heaters heat up the sensor until the engine warms up.
