Go Back   Automotive Forums Car Chat > Chevrolet > Express | G Van
Old 12-30-2013, 04:02 PM
gramos gramos is offline
Wont start
I HAVE A 2004 CHEVY G3500 6.0 my genisys tells me my crankshaft sensor is bad to replace it i did and the van will not start need some help
Old 12-30-2013, 06:39 PM
maxwedge maxwedge is offline
A990 racer
Re: Wont start
You may have a crank sensor code, I assume, but other issues can cause this, wiring to and from the sensor, do you see cranking rpms on the scanner?
Old 01-13-2014, 05:49 AM
rhandwor rhandwor is offline
Re: Wont start
Remember these are 4-wire sensors. Make sure it has 12 volt power for the sensor heater. If the old sensor had burned wire you may have blown a fuse.
Old 11-25-2014, 02:11 AM
collision1 collision1 is offline
Re: Wont start
Make sure the crankshaft sensor are line up correctly.
