Old 12-29-2013, 02:46 PM
CREWZN CREWZN is offline
Taurus 95 SE No Flashers or directionals
I have checked fuses and then replaced the flasher (under the dash 3 pronge box but still not luck. This started when I pressed the flasher button to use them but it did not work, and after that the directionals did not work either. I get no light on the dash when the directional is turned on, like you do when one bulb may be out. Any ideas of what to check would be appreciated.
Old 12-29-2013, 10:14 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Taurus 95 SE No Flashers or directionals
Sounds like a problem with the multifunction switch (MFS). Based on the title, and before reading your post, I was planning to suggest you cycle the 4-way flasher switch a few times to see if that would get the flashers working. I experienced once where my turn signals in my 1998 SHO stopped working, and after a few cycles of the MFS they started working again. I used Caig De-Oxit in the switch and they continued to work fine for several more years. Replacing the MFS isn't all that difficult though either, and is a fairly common issue.
-Rod
The Following User Says Thank You to shorod For This Useful Post:
CREWZN (01-11-2014)
Old 01-11-2014, 02:41 PM
Thanks the multifunction switch correct the problem. Thanks
Old 01-11-2014, 04:28 PM
shorod's Avatar
SHO No Mo
Glad to hear you got it fixed. Thank you for following up on your post!
-Rod
