I have a 2000 Tahoe with the 5.3L V-8, 351,000 (yes that is correct) miles. Runs great except it has recently developed a stutter, hesitation, skip, I don't really know how to describe it, under acceleration or at steady speed. This is an intermittent problem and it is driving me batty. The only codes are a P0420, maybe after 350k miles it needs replaced? Would that possibly cause this issue, or am I looking at something more sinister?
Re: Help, hesitation or stutter on 2000 Tahoe
I think its still got some life left in in. Sounds like either 1) cat is bad 2) oxy sensors are bad 3) other sensors are bad 4) exhaust leak. Yeah I know its vague. Could even be ignition but it would probably throw a misfire code.
Im leaning towards catalatic converter. It could be other things though, do you have any other codes?
"He who makes a beast out of himself gets rid of the pain of being a man."---Dr Samuel Johnson |
If the engine had miss fires the PCM would throw a p0300 code faster than you know who telling lies.
with the question asked I can tell he is experienced in auto repair . also he is a 300,000 mile vehicle owner. that is saying something about his knowledge. |
my reply to your question got blown away . I stated earlier today to swap the downstream O2 sensors and if you got the p0430 code then the O2 sensor is bad . if the swap results in the same p0420 code then the cat converter is most likely bad. then I would check that the fuel regulator is not damaged with a vac leak . check fuel pressures so that your sure the injectors and regulator are not leaking down . |
Like I stated before, I would suspect cat.
I was vague in what I thought of the other sensors. But as you called out, missfire will flip a CEL faster than anything. and it being the only code that is thrown, its making me think its either the cat or O2 sensor. If it is some other sensor it would probably throw a code: EGR, MAF etc. Maf would give lean error. So we arrive back to where we were, its gotta be the sensor or the cat. I thinking cat.
| The Following User Says Thank You to SleepyHead98 For This Useful Post: | ||
j cAT (12-30-2013)
Unfortunately, I replaced the cat last night and it still throws the code. Runs much better, but still got the code today. I'm thinking about replacing the O2 sensors on that side at least.
I guess your not aware that before replacing these converters you must first make sure you do not have any engine issues that would cause a converter failure/damage. as you are aware I recommended you swap these O2 sensors reset the dtc and see what codes come on. this is backwards troubleshooting and you may find your new converter will fail soon. with the engine cold start engine place one hand on each converter they should both heat up at the same rate. using a temp reader see if one is getting too hot . this may mean an engine / fuel failure causing unburned fuel passing to the converter[s]... |
OK, so maybe I had a mental lapse after the late night converter install. I must not have cleared the codes afterwards. Cleared them, then after about 300 miles driven, still no codes and it's running great. Before the new converter, the codes would come back every time after the engine reached operating temperature. Thanks for all the help guys.
could be with high mileage oil consumption caused the failure. the O2 sensors should be changed at 140,ooo miles. the upstream O2 is most important. the O2 makers recommend 100,000 miles. be watchful of the new converter getting too hot. using a temp reader see if they are around the same temp .. good luck |
