Old 12-28-2013, 09:59 AM
Fred_Bear Fred_Bear is offline
blower motor resistor replaced
2000 Alero. Wife reported to me she had no blower motor. I pulled the motor and it tested good. Next I replaced the resistor with one from auto zone. Now I have blower in all but the 5th and highest position. I suspect a bad new resistor but I left it for now because it's a pain to remove.
Could I have got a bad resistor? In my experience a bad resistor will give you high and nothing else. But I dunno what would give me everything but high. Any suggestions?
Old 12-28-2013, 10:43 AM
Tech II Tech II is offline
Re: blower motor resistor replaced
From the schematic, you can see that high speed power to the blower motor goes through the high speed relay....there is also a high speed 30 amp fuse....
Did you check the fuse? Did you check to see if the relay clicks when high speed is called for? Try swapping a relay?
Old 12-28-2013, 10:50 AM
no I did not check that. But I most certainly will!! Thanks for the info. I hope this is it. Is that located under the hood?
Old 12-28-2013, 12:25 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
As called out in the above schematic, the blower relay is located in the "underhood junction block". The underside (possibly the top) of the cover will show you where the relay is. If you can find a identical relay to that one in the junction box you can swap positions and see if the fan works.
The Following User Says Thank You to gmtech1 For This Useful Post:
Fred_Bear (12-28-2013)
Old 12-28-2013, 12:34 PM
ok, just making sure. Wife is at work with the car right now but I will be sure to check it. Thanks for the help.
