problem with a 4l60e transmission
Hello I have a 1996 Silverado and it will not shift out of first gear. I have had the pickup for about 6 months and when I got it, it would shift if I accelerated to about 30 and let off but then I went though some mud and got stuck,i kept shifting from reverse to forward and I got out of the mud and it would not come out of first but reverse works fine and it will not shift manually at all the pickup has a 4l60e transmission. Does anybody have suggestions of what I should do
Re: problem with a 4l60e transmission
make sure they use the new now approved GM dexronVI fluid. DEXRON III IS A NON APPROVED GM FLUID SERVICE CHANGE 2006. |
What do you think it's wrong with the transmission and could it just be a shift solenoid
Are you sure it is 1st not second, if it is second, this is limp mode and yes it could be a solenoid, I would start off with a full scan at a trans shop to see there are any pending codes and they can command upshifts to see what is what.
Well it will shift if I go around 30 and let off but even if I barely touch the throttle it will downshift back into first
It will usually break center sprag or case.
