Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 12-24-2013, 06:26 PM
cureton053 cureton053 is offline
94 gmc 1500 flooding
I have a 94 gmc 1500 that floods on start up after it is warm and i have change the temp sending unit the one with two wires i also changed the fuel pump ,egr,pluges and wires ,dist cap and roter butten ,injecters ,and no change dont now what els to change
Old 12-25-2013, 09:39 AM
maxwedge maxwedge is offline
A990 racer
Re: 94 gmc 1500 flooding
Assuming it is in fact a flooding condition, the fp regulator in the throttle body is the usual issue. Again assumes, throttle body not Vortec.
Old 12-25-2013, 12:41 PM
it is throtle body and i replaced the regulater as well in the morning when i start it it idels up like it should but when it comes down like it should it dies i start it back and same thing until after the third try and i drive it in the morning for a few minets it aks like the fuel filter is stoped up
Old 12-29-2013, 01:14 PM
fantastic's Avatar
fantastic fantastic is offline
Could it be the throttle adjustment screw.??? It seems like the choke works and you've done a lot of replacing so I'm wondering if you just need to adjust the throttle cable??
Does it drive normally or does it die while your driving down the road? Or is it only at idle times and start ups??
Last edited by fantastic; 12-29-2013 at 01:16 PM. Reason: Another question came to mind
Old 01-04-2014, 06:43 AM
rhandwor rhandwor is offline
I had one of this year come that was using an excessive amount of gas. I put my scanner on it and drove until it should have been up to temperature which it should have. I got out and felt the hoses thermostat was stuck open. Using a flashlight it was pouring gas out of the fuel injector.
I installed a new thermostat and that fixed the problem. The customer said it went from 4mpg to around 11mpg.
Crack manifold next to oxygen sensor leaking intake,leaking vacuum hoses will cause them to run rich.
