Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 11-12-2001, 09:01 PM
Russ Russ is offline
Question 97' E36-anyone running 235 tires?
I've got a 97' E36 with stock 16x7 wheels and 225/50-16 tires.
I'm trying to upgrade to 17x8.5 and run 235/40-17 tires. The people at the Tire Rack say, going to a 235 tire will result in some rubbing.
Anyone out there running 235's on an E36 experiencing rubbing?
The BMW dealer is not recommending going to a 17" wheel.
Old 11-13-2001, 02:53 PM
Sean`02///325ci Sean`02///325ci is offline
Hi, on my 97 328i, i went 245 40R17 on 17*7.5". i know for sure without lowering you can go upto max of 9.6" front and back, if you lower than you will rub.
Tirerack will give you the specs for the tire width on the mounting rim according to the rim-width.
`Regards Sean
Old 12-22-2001, 12:50 PM
Blown ///M3 Blown ///M3 is offline
Wink
I HAVE 265 ON MY 99 E36 M3 1.5 DROP NO RUBBING PROBLEMS:smoker2: SO YOU SHOULD BE COOL WITH 235'S
Old 01-11-2002, 04:12 PM
ASAABOY ASAABOY is offline
235's should have no problems. I have 235/40/17 on my e36 plus a 1.75 inch drop. There are no rubbing
Old 01-12-2002, 12:15 PM
taissel taissel is offline
There will be no problem because i have the same combo with 2 inch drop and no Problems with rubbing
Old 02-25-2002, 06:02 AM
sunken sunken is offline
I drive with Breytons Vision 9*19 with 235-35-19 without any problems.
Black is beautiful
235 tire too big for 96 cavalier? letxen3 Cavalier 4 04-24-2007 11:04 AM
To anyone running 225/70/16 tires JonRav4 RAV4 1 09-30-2004 02:49 PM
Anyone running a single turbo? medici78 General 22 07-03-2002 08:39 AM
97' E36- alum. dash trimkits? Russ 3 Series 0 11-14-2001 11:12 AM
97' E36, 17x8.5 too wide? Mods? Russ 3 Series 1 11-13-2001 10:04 PM
