Old 12-20-2013, 07:17 PM
TiberiusX90 TiberiusX90 is offline
97 blazer front differential problem
I just completely replaced the whole front carrier minus the axles on my 97 Chevy blazer and now when I took it out for a test run the steering feels like it grabs and pulls to one side then the other or the tires are grabbing oddly, and I am confused as to why exactly. I made sure the axles were seated properly and everything was hooked up and bolted together right. Please help me.
Thanks
Old 12-21-2013, 10:37 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 97 blazer front differential problem
Thanks
Need more info here t help you.
Does it do it only 2W or 4W or both?
Or going straight down road or turning or with braking ?
MT
Old 12-21-2013, 07:45 PM
It does it in 4 hi, 4 low (not as much though) and 2 wheel.
And it seems to do it all the time although it does it more going straight down the road.
Old 12-21-2013, 07:54 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Was this a used, complete front diff? Less the CV axles? If so, it sounds like a problem with the used unit.
Old 12-21-2013, 07:57 PM
Yes it was a used complete front diff no axles or anything else...
I was afraid it might be that
Old 12-21-2013, 08:04 PM
gmtech1's Avatar
Most places will offer a 30 day warranty on use parts like that. Also, when replacing used diff's like that, you need to be sure it has the same gear ratio as the original.
