Old 12-19-2013, 02:10 PM
tinkering's Avatar
tinkering tinkering is offline
In the 200 Club
Question Jounce bumper bracket rusted bad
1996 Chevy 2500 (3/4 Ton) 4x4
My vehicle inspection wouldn't pass the jounce bumper bracket (stops upper control arm from traveling too far) on the drivers side front. The bracket is rusting out and needs to be repaired or replaced. The bracket is welded to the frame. Does it sound feasible to cut a bracket off at the wreckers and weld it to my frame? Do they allow zip disk cutters in Pull a Part? The passenger side bracket is OK.
Old 12-19-2013, 10:06 PM
Schurkey Schurkey is offline
Re: Jounce bumper bracket rusted bad
Seems like a reasonable fix, provided the rest of your frame is acceptably free of rot.
I think you'd have to discuss your removal methods with the Treasure Yard you intend to do business with.
Be sure to wear eye and ear protection. Die grinders are noisy as hell in the best case, they're worse in an enclosed area like the wheelhouse/inner fender. The sparks and bits of cutting wheel go everywhere.
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
The Following User Says Thank You to Schurkey For This Useful Post:
tinkering (12-26-2013)
Old 12-26-2013, 02:08 PM
tinkering's Avatar
In the 200 Club
The bracket is very inaccessible at the frame because of body parts etc. in the way; it is undesirable to cut the bracket off; I would have to leave an inch or two of it on the frame and then weld an equal piece of another bracket on to the amount I left on the frame. On top of that, Pick n Pull doesn't allow any 'spark generating' tools in the yard. I am going to beef up the weak spot/s of existing bracket by welding some plate metal to it, and by replacing the rubber bumper. That should be more than enough to pass the inspection; it will be stronger than new.
Old 01-06-2014, 11:56 PM
tinkering's Avatar
In the 200 Club
We used 1/8" steel plate; we cut and bent a piece to fit down in the inside bottom of the bracket, while rising up the middle back cross section ; my wizard welded it along the front and sides and VOILA!
