Old 06-20-2003, 07:23 AM
fredo fredo is offline
Sanding
Hello,
I'm relatively new in this forum and find it very very useful.
The FAQ talks a lot about sanding :
- first to remove mold lines...
- then after painting to remove the orange peel and to give a good shine.
The question I have is : which device do you use to sand ?
Sanding block (which type, which size) ?
Your fingers ?
I'd like to know. I have been using my fingers but I find it difficult for certain areas.
Thanks for your help.
Frederic
Old 06-20-2003, 07:39 AM
primera man's Avatar
"P-Man"
I do all my sanding using my fingers. Its very hard to get a area large enough or flat enough to have to use a cork block etc.
What you are doing should be fine.
View All My Models Here.
Old 06-20-2003, 03:06 PM
hirofkd's Avatar
hirofkd hirofkd is offline
You can cut a sand paper, and wrap it around the tooth pick to make a fine sanding rod, flatten the tip, and you have a sanding knife etc. You can change the shape of the tip by how you hold the sand paper and how you glue it to the "bone" or it.
Hiroaki Fukuda
Old 06-20-2003, 05:13 PM
tdoty tdoty is offline
sanding
You can also use sanding sticks, either the replaceable belt type or "emery boards" from the health and beauty section, or the foam core type. Some of the foam-core boards are being marketed FOR hobby use and are available in multiple grades. Funny thing, to me, is that the most useful board is pink!
I also get foam blocks from work that make wonderful sanding blocks - they're water resistant and have adhesive on one side......but I can't think of a generally available equivalent.
HTH,
Tim D.
http://modelcartech.com
Old 06-20-2003, 06:11 PM
chaos's Avatar
chaos chaos is offline
AF Premium User
Re: sanding
Tim, what grit are the pink hobby ones?
Old 06-20-2003, 07:40 PM
Well, I'm not really sure what grit the pink ones are - they feel like about 400 grit to me. That's about the best I can do right now
Tim D.
Old 06-20-2003, 08:08 PM
bah humbug's Avatar
I was about to say the same thing.
I do this for spaces that are too small for my fingers to sand.
But for orange peel and mold lines I mostly use my hands/fingers.
Decals - Clear coat & Sanding grit Zman007 Auto Collision Network 1 12-24-2010 07:52 AM
sanding base for clear? Swansen Auto Collision Network 7 07-22-2009 11:31 AM
1st time wet sanding & uhh... did i mess up sanding or painting? chato de shamrock Car Modeling 13 03-10-2007 07:28 PM
Sanding or not sanding Svendsen Car Modeling 4 06-08-2006 11:25 AM
I need sand ladders. Matt Peckham Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 14 07-24-2001 06:30 PM
