Old 12-11-2013, 11:02 PM
oldguy2 oldguy2 is offline
Tiny Lunds 69 camaro
I'm building Tinys #55 69 camaro and looking for interior and engine pics...
plus what engine he had in the car...thanks...
Old 12-13-2013, 11:44 PM
modlman17's Avatar
modlman17 modlman17 is offline
Re: Tiny Lunds 69 camaro
Check at http://www.randyayersmodeling.com/mo...orum/index.php. We have had several threads about that car there.
Rob
Old 12-19-2013, 01:34 PM
I use that site for alot of info for my builds,BUT the problem is sometimes you have to go thru up to a thousand or more to find the actual info that you want...
Old 12-19-2013, 03:04 PM
indy1977tx indy1977tx is offline
When using the search feature on RANMF make sure you look at these options:
Search for any terms or use query as entered
Search for all terms
The default is the top, so if you search for "Lund Camaro" you get any thread with any mention of Lund and any thread with Camaro mentioned in it. If you switch the option to "Search for all term" then it returns only threads that have Lund and Camaro in it.
The difference is 1,552 results versus 31. Looking through 31 is certainly manageable, since you know that these results are much more likely to be on point. Hope that helps.
Jordan
Old 12-19-2013, 05:05 PM
thanks,that helped alot,still can't find pics of the engine bay or what engine was used and any interior pics...
