Go Back   Automotive Forums Car Chat > Dodge > Ram Van
Old 12-11-2013, 03:41 AM
Meridivs's Avatar
Meridivs Meridivs is offline
Exclamation Hard to get into Reverse when cold 96 B2500 Ram Van
We have recently acquired a '96 Dodge RAM B2500 Conversion Van.
Since winter came around it developed a strange problem just after starting - if we try to put it into reverse with the transmission cold it would sit for around 40-50 seconds doing nothing then it would "bump" hard into gear.
With the AT fluid hot everything works as it should, the Reverse engages smoothly as soon as we move the lever.
Any idea why this happens and how we can fix it?
Old 12-11-2013, 09:31 AM
alloro alloro is offline
Re: Hard to get into Reverse when cold 96 B2500 Ram Van
You might be due for a fluid/filter change and at the same time the low/reverse band should be adjusted. In the meantime, first shift into Drive for a few seconds, then shift to Reverse. Shifting into Drive gets the fluid pumping through the tranny faster.
Old 12-11-2013, 11:06 AM
rspringfield rspringfield is offline
Smile Re: Hard to get into Reverse when cold 96 B2500 Ram Van
on my 96 3500 putting it in gear and foot on the brake for about 10 seconds I have good results, then shift in to reverse
