Go Back   Automotive Forums Car Chat > Buick > Skylark
Old 12-10-2013, 03:35 PM
crazyoldergirlie crazyoldergirlie is offline
1996 Buick Skylark HELP!
Please HELP, 1996 Buick Skylark can anyone tell me why SMOKE is coming out of the air vents.
Old 12-10-2013, 06:32 PM
maxwedge maxwedge is offline
A990 racer
Re: 1996 Buick Skylark HELP!
More than likely the heater core is leaking, should have a sort of a sweet smell.
Old 12-11-2013, 04:33 PM
It isn't the heater core any other suggestions? Thank you
Old 12-11-2013, 06:12 PM
aleekat aleekat is offline
Smoke? As in something is actually burning??
"Smoke, Mist or Fog will come out of your A/C vents on hot, humid days. The reason for this normal phenomenom is the cold, dry air coming from your A/C vents is lower than the dewpoint of the interior cabin. Basically what this means is that cold, dry air is mixing with hot, humid air and causing the smoke. This is similar to when you open your freezer door and see the fog coming from the freezer. This is a normal condition and will eventually dissipate once the temperatures in the interior cabin and the A/C vents start to balance out. One way to quickly balance the temperature out is to keep the A/C system on recirculated intake air."
Post back, that's what makes Forums Work.
Old 12-11-2013, 07:16 PM
A990 racer
Issue here is vapor vs " smoke" from here we really don't know..
The Following User Says Thank You to maxwedge For This Useful Post:
SleepyHead98 (12-11-2013)
