Old 12-08-2013, 10:56 AM
makuloco2000 makuloco2000 is offline
Bench Bleeding Master Cylinder
So I got a Taurus in today with a pretty good leak from the rear piston seal of the master cylinder and since this is pretty common on the Taurus I decided to show the bench bleed procedure you have to do before putting a new master on. Take a look under the master cylinder on the brake booster and you will likely see brake fluid seepage and bubbling paint. The customer chose Dorman for a replacement over OEM and it actually came with the bleeder kit in the box! Just an FYI I am sure it will help someone.
