Go Back   Automotive Forums Car Chat > Mazda > MX-5/ Miata
Old 12-07-2013, 09:30 AM
rich2 rich2 is offline
2002 miata no spark
I have replaced plugs, wires, coils, crank angle sensor, cam position sensor . Have power to everything, will not trigger spark. any suggestions, Thanks Rich
Old 12-07-2013, 11:24 AM
StreetShotz StreetShotz is offline
Re: 2002 miata no spark
Have you tried pulling a plug to confirm you are not getting spark?
You can get spark testers from local parts stores but you can do it the "ghetto" way and pull a plug, put it in the lead (pull the fuse for the fuel pump as well) and ground the plug to the frame and watch for a spark.
Old 12-07-2013, 12:31 PM
Smile Re: 2002 miata no spark
yes have checked with spark tester as well as getto method Thanks Rich
Old 12-07-2013, 12:45 PM
aleekat aleekat is offline
Any codes?
Post back, that's what makes Forums Work.
Old 12-07-2013, 01:36 PM
no codes
Thanks again
